Tiger Tool - программа для сброса ошибок и прочего через OBD
Добавлено: 20.12.2018, 12:34
На соседнем ресурсе английские тигроводы создали программу для ноутбука для сброса ошибок/ключика, калибровки заслонок и прокачки АБС (в последней версии).
Оригинальная тема(закрытый раздел, требуется регистрация):
https://www.tiger800.co.uk/index.php/topic,24213.0.html
Оригинальное описание (кому лень регистрироваться на чужом форуме):
Инструкция на аГлиццком:
https://yadi.sk/d/D1VcDYE93YeTtQ
Сама программа:
https://yadi.sk/d/BtD5i6vp3YeTsj
Обсудим?
- Спойлер
- TigerTool V2.5 is now released.
Subject to the disclaimer below, this software supports the Tiger 800 & Tiger Explorer including the 2017 versions.
In addition to resetting the service interval announcment (SIA), checking & erasing diagnostic trouble codes (DTCs) including ABS codes and checking the throttle body balancing, this version includes bug fixes and now has the ABS Bleed function added.
DISCLAIMER
These instructions and the attached software are provided as-is and without warranty of any sort.
The software is provided free of charge for non-commercial use. It allows the user limited access to the ECU on Triumph Tiger 800 and Explorer models ONLY, and can be used to perform various functions as part of a regular maintenance and/or servicing schedule.
Using this software, and the consequences therein, remains the sole responsibility of the user. Neither the author nor anyone associated with the officially supported forums will be held liable for any subsequent costs, losses or damages as a result of downloading, installing or using this software.
The software MUST NOT be copied to other websites, internet forums, social media sites etc without the express written authority of the original author. Software support and new releases will only be provided by the author via the forums at Tiger800.co.uk and Tiger-Explorer.com.
All reasonable steps have been taken to ensure the accuracy of the instructions and suitability of the software, but be aware that editing or modifying your bike's ECU may cause undesirable effects and/or invalidate your warranty. The software has been scanned at VirusTotal prior to release.
OBD Interface
Accessing ECU data can be achieved using the ISO9141-2 and ISO15765-4 (aka CAN bus) protocols. This software is intended to work with most USB & Bluetooth ELM327-based OBD2 interfaces, including clones. There are a number of ELM327-based interfaces around that don't work with TigerTool because they contain very poor quality components and/or firmware and don't support some the of the basic ELM327 commands that are needed, in particular 'AT D'. Some of the USB interfaces have the FTDI USB-to-serial chipsets which seem to work well under any version of Windows, as FTDI are usually on-the-ball with releasing drivers. Unfortunately FTDI released driver updates a few back that bricked many of the clone chips that were being used in cheap OBD2 interfaces so it can be a case of buyer beware. There are also many interfaces that use different serial chipsets, e.g. the PL2303 interface from Prolific Tech, and most of these have been tested. The key is to ensure that you have the latest drivers for the device that you're using to support the version of Windows that your PC is running.
NOTE:
• This software WILL NOT work with the VAG/KKL leads such as those from Lonelec that are used with TuneECU.
• This version supports ELM327 OBD2 interfaces that are V1.n or V2.n.
Installation
As stated with previous versions of TigerTool, I'm no software engineer so the file size for this application is much larger than it could be. However, when I do write software I try to make it robust & fit for purpose, and spend a lot of time looking for bugs and trying to break it.
TigerTool is a standalone application that needs no installation process and no additional files to run. You can manually add a shortcut to your desktop to make access easier if you like. This latest TigerTool software has been thoroughly tested on my 2011 Tiger 800XC & 2012 Tiger Explorer using Windows versions XP (SP3), 7 (Starter), 8.1Pro and 10 Pro. Several Beta testers have also checked it on various other combinations. The screenshots used in the following instructions were all taken from within Windows XP but it should look similar under other Windows versions.
Download the zip file attachment at the bottom of this post then save & extract the single executable 'TigerTool.exe' file from within the zip to a suitable folder on your PC.
The latest instructions have been put into a separate PDF that's also attached below as a zip file. This file contains some important information so you MUST download and read it thoroughly before using the software.
You should find this latest update useful & just as easy to use as previous versions. If you have any questions or problems then just ask in this topic.
Сама программа:
Обсудим?
